Adjusting the L/R balance on two paired WiiM Sound units
-RoBo-
I have a WiiM Sound and a WiiM Sound Lite paired in stereo, and I’d like to be able to manually adjust the balance between the two speakers.
This feature is not currently available.
Could it be included in a future version of the WiiM Home app?
Regards,
Ronan
Upvote 0
Regards,
Ronan
Welcome.
Is this a one-off balance to get it how you want it, or being able to adjust easily at will?
If the former you should be able to use the Audio Settings / Volume Limit option on one of them to make it slightly quieter.
Thank you for your prompt reply :^)
A real scale would be even better, but the solution you suggested does work.
