Am I losing a lot of quality for using Airplay with spotify to have volume normalization?
Spotify has a bitrate of up to 320kbps, and Airplay can support up to 24/48 lossless so I’d say it has more than enough bandwidth for it.
Can you hear a difference? You might be pushed hearing a difference even with Bluetooth.
I believe the lower bitrate you quote is for Apple Music and AirPlay 2 which transmits 256kbps AAC streams. The bitrate for CD quality streams is up to 1440kbps and as I say, I understand AirPlay 2 can achieve 24/48 which is even higher.
Please read my edit and link explanation of 24 bit Apple Music
Yeah, aware of that thanks, but in the context of WiiM and other non-Apple devices, I stand by what I say :)
Ok 👍
I am a huge apple fan but never use airplay and don’t use Apple Music or Spotify googled the answer for the original poster I will go away now 😊
Yeah, Apple Music and Airplay 2 in particular is a bit of a “soup sandwich” - see this oft quoted link
Cheers :)
Not really sure coz the volume seems to be changing when switching. Also im new to hifi so i lack knowledge on numbers and graphs but earlier while switching back and forth i could hear some difference, like cymbals echoing at higher pitch but maybe it’s just the volume/normalization…
As you say, it might be the normalisation as Airplay should be able to accommodate Spotify no matter how it’s being played.
256 Kbps
AirPlay 2 supports lossless, 16-bit/44.1kHz CD-quality audio streams1. The bitrate for AirPlay 2 is 256 Kbps2.
Airplay 1 is a different animal
Explains the 24 bit on airplay and how you can get it
Using airplay, this is what wiim’s says 900kbps 16bit 44.1
Yeah, that’s fairly standard for airplay on WiiM, although I wouldn’t get too hung up with the 900kbps figure as it seldom varies and doesn’t really say anything about the resolution/quality of what it’s sending. Like ChromeCast and AlexaCast, they’d be as well not displaying that 900kbps as it’s potentially misleading.
