Amazon Unlimited Audio quality when connected via Chromecast?
LennyBruce
Does Chromecast carry the full UHD and HD signals when connected through the Amazon Music app?
It should up to the capability of your WiiM device not note the Ultra’s Castlite is currently (?) limited to 24/48. Note that it won’t be gapless and that you should be using AlexaCast if possible as it is gapless and will support up to 24/192.
Thanks for that.
The Amazon Music app is a better interface than accessing it through Wiim Home and there is loads of stuff at 24/192.
To the OP: Activate AlexaCast to cast from AMU to the Ultra - full bit perfect up to 192kHz.
If you’re going to use ultra chromecast it would be a disaster, it lag, it stop in middle and skip. Use Amazon Alexa cast instead.
