New WiiM Amp Pro owner here. Read the prior threads on this topic and have tried everything recommended (and have started a support ticket with WiiM). Those threads are a bit older, so hoping there is some new advice out there.
Set up: Amp Pro, LS50 Metas, SVS powered PB1000 sub, Cambridge Audio Alva Duo phono preamp, Fluance RT85 TT. Everything is less than one month old. Good quality speaker cables and interconnects.
Controlling the Amp Pro from iPhone 15. WiiM Home app is latest and Amp Pro firmware is latest. Sub crossed over at 80hz and main speakers are set for bass pass through. Everything was working GREAT until a few days ago. Without any changes that we are aware of regarding hardware or software, the sub simply stopped getting output from the WiiM Amp Pro (both streaming and phono). I've gone through the disconnect/reset/power on-off/cable check routines. Nothing. Not an issue with the sub itself, as I confirmed running it with another system to check.
"Maybe" there was a recent WiiM update pushed out that we aren't aware of and which resulted in this. I can't think of any other cause or any other solution.
Any advice appreciated!
