A andyrice New Member Joined May 26, 2023 Messages 6 May 26, 2023 #1 I want to use a Mini Pro to feed into an integrated amp. that only has analog inputs. What is the maximum audio resolution of the Pro's analog output?
D d6jg Major Contributor Joined Nov 22, 2022 Messages 2,917 May 26, 2023 #2 The Pro's onboard DAC will convert up to 24/192 to analogue for you - it is perfectly OK just not quite state of the art.
Brantome Major Contributor Joined Oct 20, 2022 Messages 6,842 May 26, 2023 #3 Analogue output doesn’t have a resolution.
D1N0 Valued Contributor Joined Apr 30, 2023 Messages 336 May 27, 2023 #4 20.000hz if you are still in puberty
