I was trying to use the Aux output from a WiiM Mini into a JBL Partybox 310 so I could get Wi-Fi audio (AirPlay) but was getting noticeable higher frequency static from the speaker. I tried setting the WiiM to 500 mVrms (which reduced it significantly) and setting the volume to fixed, but that wasn’t enough to eliminate the issue. The PartyBox speaker specs say its Aux port sensitivity is 250 mVrms. Can this be solved? I’m trying to avoid Bluetooth for latency reasons (I am syncing sound with Apple TV video). Thank you for your help!
