Auto-Turn-On works only for HDMI & Roon, but not for Optical-In
makli
My WiiM Ultra turns on automatically if receiving signals from TV by HDMI input or from my Roon-Server by network input … absolutely correct.
But if the WiiM Ultra receives signals by optical input, nothing happens and I have to switch on the WiiM Ultra manually … that's annoying!
Is there any possibility to activate the automatic turn-on for the optical input too?
Auto sensing for optical is linked with HDMI so it's strange one works but the other doesn't - try toggling the setting off and on and see if that helps.
With my pro plus, Auto-Sensing Optical-in is a separate setting tick-box,
Along with this I need to change my TV settings to send audio via the speaker optical cable, its not automatic, so also check your TV settings?
