Best Subwoofer to WiiM Amp
Satty33
Good afternoon. I'm new to the WiiM Amp and was wondering which subwoofer works best with WiiM. Thank you in advance.
This is a common one for a reasonable price. Use the room correction in the WiiM app to blend it in. There are lots of others. Don't skimp on getting lower Hz.
Since the WiiM Amp will do all the low pass filtering of the subwoofer and high pass filtering of the main speakers, the subwoofer of your choice should ideally have an LFE input, bypassing the sub's own crossover. Some subwoofers don't allow to set the crossover point high enough to not interfere with the crossover set by the WiiM Amp.
You don't need continuous phase control on the subwoofer, since the WiiM Amp allows to fine tune the delay between subwoofer and mains very precisely in 1 ms steps. You don't even need a phase switch (0° or 180°), since the WiiM has that too (but there are probably very few subwoofers that come without it).
There's no need for any fancy DSP processing on the sub, because - once again - the WiiM Amp can do the same thing. Of course, if you end up wanting a subwoofer with its own DSP and/or room correction, that's no reason to avoid it. You could always find out for yourself if you prefer the sub or the WiiM Amp to do this for you. But you can probably save some money by buying a more basic subwoofer.
If the subwoofer you are looking for offers high level inputs (to be connected in parallel to the loudspeaker output of the amp): Simply don't use them.
any active subwoofer with line level input.
Also there is no such thing as "too much sub" , within reason
The sub needs to match your speakers. Basically if you have small speakers you do not want a massive sub.
akshully the smaller the speakers, the more you're asking of the sub. If you have huge towers that go low, then you are only asking the subwoofer to output very low frequencies.
As for the question how much sub, that depends on room size and expected output
But typically a 12" subwoofer will be plenty for a music system. Having duals will even frequency response however the wiim cannot manage two subwoofers, and you would need to get them in the best location first, then matching to each other, then get the wiim to align the matched pair
For the WiiM Amp, many users recommend the SVS SB-1000 or the Klipsch R-100SW for great performance. Both deliver solid bass and pair well with the amp.
Another vote for one of the RSL Speedwoofers:10E, 10S, or 12S. It would be helpful if you can specify how much you want to spend and where int the world you are located.
