Changing the WiFi in connected device
asktheages
Hello.
I juzt bought the Mini, and used it at home so far. Today im at work and I just cant connect . It shows its glued to my home WiFi. Cant find the device "again" to have two setups active, and dont know how to change the WiFi manualy without removing the device.
Is there any way to make it work ?
Hello.
Unfortunately, WiiM doesn't have the ability to change Wi-Fi. The only way to connect to a different SSID is a factory reset. Please reset it and set up again.
