I have a WiiM pro that I have used stand-alone for over a year and it works great. I have a friend with a house with its original multi-room audio system from the mid-1990’s. It consists of a long-discontinued amp/controller for 8 zones that used proprietary hardware panels for control. The speakers for the entire house run to a single room and are accessible. The desired solution would have the following:
The key use cases are:
1) Stream music into the three zones on the ground floor separately AND as a group
2) Play music into each of the other zones separately and as part of a whole house group
I understand I need a multi-zone amp and a possibly some WiiM device per zone, which is all fine. Here are my questions:
1) I want to name each WiiM for its zone and have visitors interact ONLY through their music app of choice, selecting the room where music is desired. I have seen this work and think it’s no problem for non-grouped situations.
2) I want to create 2 groups - (a) “ground floor” and (b) “whole house”. I would like the groups to be permanent and accessible as options when picking where to play music from ANY music app and without using the WiiM app. So in this case, you would see listed: zones 1, 2, 3 and ‘entire ground floor’ for the main floor, and 4, 5 and 6 for the bedrooms, and ‘whole house’.
My question is can you create permanent groups that are visible in music apps outside the WiiM App. I don’t want visitors to use the WiiM app at all.
Next question is in this scenario, can I use a single PRO and then mini’s for each channel connected to the amp?
Hope this makes sense. THANKS in advance for your helpful feedback.
John
John
