DLNA track length progress
bird
Location
Germany
When playing music via a DLNA connection there is no track length and progress displayed. I have this issue on the mac app as well as on the mobile android app.
Is there a way to fix that?
I haven't had any problems like this, nor do I remember any similar reports, so without any more information I'd have to assume it's down to your DLNA server or possibly the type of file you're streaming.
Try using the Android control point BubbleUPnP to see if it too has the same problem.
What DLNA server are you using, and what file type are you playing?
Yes it works with BubbleUPnP. I stream FLACs and mp3s from a Teufel Raumfel.
I'm afraid I don't know what that is, and google isn't much help either.
Assuming it's a DLNA server, and given that BubbleUPnP seems to work I'd submit a ticket from the WiiM Home App (Settings > Send us feedback).
EDIT: A link to the product page might help, and maybe a screenshot of the server properties from BubbleUPnP (Vertical ellipsis > Info) might be enough assuming it's not a bespoke/rebadged UPnP server.
