EQ difficult to accurately adjust
gazza1101
Active member
I find the EQ difficult to adjust accurately, it might be my fat old fingers:)
It would be great to see a + at the top and a- at the bottom so as to be able to adjust it easier:)
It's exactly the same trying to set the frequency range for room correction. You set it for exactly the frequency you want and when you remove your finger it changes 🤣
(It would be nice to be able to switch to full screen graph and above all to truly present the response in detail, see the reactions to the q factors in ls or hs mode in peq etc... much too crude to be useful....)
Same, and also for any other navigation where a ”dot” and a level is used for adjusting :D
Perhaps we should do a ”Feature request” for ”Fat finger compatible”-GUI elements!
