maximilianXI
Good day! Does it make sense to buy more expensive power cables (e.g., Audioquest) to get even more out of the Vibelink Amp and Ultra? Does anyone have experience with this? Thanks, Markus
"You’re going to get a lot of no and lots of science." --> Because that is the only way that makes sense and is easy to prove.You’re going to get a lot of no and lots of science. I’m a pathway to yes. I use a Topping linear power supply with my Pro Plus with pleasing results. I also use audiophile power cables throughout. If you’re not sure and you’d like to try, I’d recommend a less expensive cable first. The WAudio cable on Amazon that’s the black with red stripe is inexpensive, and was even rebranded and sold by an audiophile dealer at one point (Audiogon had a thread on this and that dealer’s shenanigans). If you get positive results, you can then explore other high-end cables if you want. If you get no results, then now you know. Good luck and best wishes.
I can only say one thing.Good day! Does it make sense to buy more expensive power cables (e.g., Audioquest) to get even more out of the Vibelink Amp and Ultra? Does anyone have experience with this? Thanks, Markus
I can imagine. All the (optical) cabling that my worldwide colleagues put in the ground also sound great.I can only say one thing.
The Optical cable included with the Ultra sounds great. And the fit is fine![]()
That's mostly because a lot of people claim to be experts when they are not.(Picture snipped)
Hmmm... Because the chassis provides the appropriate shielding?Yes. Have been reading about this audiophile power cord myth for more than 40 years.
Attached an example of the power connector for a $500 pre-amp and a $100 external power cable. If it did matter why then just these cheap wires in the amp?
This policy feeds millions of courier driversBuy one on Amazon and try it. You can return it if you do not hear a difference.
Always remember. The more expensive a product is in the audio world the more…..AUDIOPHILE…. It is. Seriously…no. Buying a new power cord will lighten wallet a little but that’s about itGood day! Does it make sense to buy more expensive power cables (e.g., Audioquest) to get even more out of the Vibelink Amp and Ultra? Does anyone have experience with this? Thanks, Markus
