External DAC PCM Filter?
F1 Fan
Valued Contributor
Location
Suffolk, United Kingdom
Hi all,
Quick question, should I enable EQ / PEQ when my Ultra is connected to my Topping D70 Pro (via USB) and the Topping has the PCM filters enabled?
Hi all,
Hi
DAC filters and EQ are different functions; the PEQ (including RC) in the WiiM can be used primarily for room acoustics correction. Regardless of whether you turn the filter on or off, you can decide to use the EQ or not.
