Fixed volume for USB out
Limopard
Adding USB audio out was a really great thing. It would be even better to enable a fixed volume setting for USB out. I connect the Wiim Amp to a Topping DX 3 pro+, which has its own volume control.
A different volume setting for every output would prevent the speakers from blasting at full volume when switched back.
Upvote 1
Seems like a good idea to me. Makes sense for those wanting to use the USB output to connect an external DAC for headphone listening.
It has also now become unusable now that the subwoofer is now enabled with the USB output, so it would be good to have the option to disable this. Can understand the logic of doing this with the Ultra, but less so with the amp.
Welcome.
Your logic seems sound, so you may need a new alias. Unfortunate, 'cos it's a good one!
Can I ask what cable you used for this?
This feature is absolutely needed or at least a way to control volume limits by audio output. I had the amp pro outputting to a DAC via USB at 100% volume and when the DAC shut off the audio went straight to the next audio output at full volume which were my speakers.
Many eardrums will be saved.
