Normally, I use my JBL Stage A130 for the Wiim Amp that works great. One time, I tried the Wiim Amp on a DIY 300 Watts 8 Ohms speaker, around 12 inch in diameter. It works fine for a couple of songs but then it blinks red and I turned off the Wiim after that. Anyone knows why that is? Also, the EQ is set to resemble the V-Shape since that's what my dad likes. For those 300 watts speakers, we usually used a Class A/B amp.
Correct me if I'm wrong but as I understand it, it shouldn't be an issue? I mean the worst it can get is that the speaker will output low volumes right?
