Having a hard time using EQ cursors
Vignus
Valued Contributor
I love playng with Wiim Ultra graphic EQ, but using those cursors drives me mad: they seem to have a will on their own, it's very hard to slide them to the value you want. Sometimes they don't respond, others they go too far down or up and when you release your finger they hardly remain where they were. I've tried both with a smart phone and a tablet (bigger screen) but the issue remains. Has anybody had the same issue and is there any workaround to this problem?
The settings bars in RoomFit act the same way. Sometimes they refuse to move and they often change when you release them.
I also have trouble with the RoomFit settings but not with the EQ bars. This is on an Android phone (One Plus). What are the devices used by OP?
Edit: I was referring to PEQ while this thread is about using GEQ. My bad.
I absolutely and unexceptionally never use the sliders. I always use the numerical inputs, sometimes I do use the plus and minus buttons when making small corrections.
The graphic EQ has no numbers that you can change directly, you can just move the sliders
Obviously I missed the term "graphic" :) ...
... maybe because ... well, I never use it. ;)
Sorry, I will edit my post so it doesn't confuse future readers.
