Help. Used to be able to stream to HomePods, now can’t.
Status
Not open for further replies.
Todashi
So I had my Wiim Pro up and working perfectly, allowing me to stream audio from a turntable, through a pre-amp and into the Wiim Pro, and then on wireless using Airplay2 to a pair of HomePod minis.
But I didn’t use the system for a couple of months and just went to play a record and can’t get it to work again. The line out option on the Wiim Pro app is only displaying line out, optical out, COAX out and Bluetooth out. I seem to recall that you could tell it to use AirPlay here, and now that option doesn’t seem too be available?
Am I missing something obvious here? Has a software update removed this option, or is it something to do with the way my WiFi network is configured in the house?
Please raise a ticket direct to WiiM via the settings/feedback section in the WiiM Home app to discuss this further. Closing comments
Status
