How to connect Wiim to Naim 282?
TBSOO
Hi.
Seeking help from naim users. How do I connect RCA output from Wiim to RCA output to Naim 282 pre amp? Do I really need to use RCA-DIN options? Was hoping to use the included RCA-RCA cable.
I have connect the naim 282 phono RCA CD input. Used BT to connect to my Wiim but no music can be heard. Can someone help as I’m not sure if I am doing it right? Thanks!
Hi.
According to the NAC 282 manual you first need to assign the RCA inputs to the matching buttons on the front panel before using them. Default input setting is to use the DIN sockets.
