Instant physical "add speaker to current group playing music" option for speakers/devices with a preset button.
conn
Valued Contributor
Location
Floriduh
I have several Audio Pro Speakers (and two WiiM streamers with remotes) with preset buttons (1,2,3,4,). Would be great if when playing music in a group if I could quickly "push preset one" and add that speaker to the current group playing music.
I'm big on trying to get away from the cell phone for controlling every single thing.
Upvote 0
You can use 5,6,7 and 8 by double pressing the numbers 1,2,3 and 4
There's also a beta test for the ultra that may be of use
There's also a mention of this in the roadmap
'Smart presets that trigger complex routines—setting input, volume, EQ, and grouping simultaneously. Persistent grouping for fixed speaker zones. Native YouTube Music support. Completely rewritten USB media engine.'
Thank you for the reply and I was aware of the extra preset settings, I was just using the 1-4 as an example. I currently use them for just for just preset music stations to play.
To me it seems like the "multi-room" aspect of WiiM is just kind of creeping by with no improvements or upgrades... I see new hardware (which is great) and lots of focus on room correction/room fit, etc... But nothing new in multi-room features or the management of multiple speakers (persistent grouping, etc..)
We still can't even create a permanent stereo pair, like with Sonos (L/R) between A10 MII's yet.... Its like they forgot about multi-room completely and went off in another direction...
  • Like
Reactions: mpr
