Keep disconnecting over wifi
JM1010
Just received my wiim pro. Playing spotify from phone over wifi but keeps disconnecting every few minutes even though wifi signal is strong. What should I do? Thanks
Try using 5ghz only. Strong signal doesn’t tell whole story as there maybe interfere on channel if you’re using 2.4ghz with your surrounding neighborhood.
I believe I have found the real cause of this super-annoying issue. There is a setting that puts the device in "standby mode", change it to "never". Once I did this connection is rock solid.
