Legs or a stand ?
Got my Wiim Sound today, very easy set up. all familiar to me as a Wiim Pro user
Nice sound so far
I note there are three threaded bolt holes in the base. Are these for legs or a stand ? are there plans ?
Any idea what thread size they are ?
Great thank you, have you seen or heard of anyone producing legs or a stand ?
In the mean time i'll just make some legs out of long bolts
:cool:
Searching for HomePod stands should yield photos useful for DIY projects.🙂
The simplest solution is to use a camera tripod. It allows for easy height adjustment.
Of course, you need a base to place the speakers.
Even if you wanted to pay shipping they don't appear to ship it to the USA.
These might be suitable, they have a top plate at least.
Ok, thank you for the reply. I have little children that might knock the speakers off of unbolted stands, so I want something where the speaker won't fall off. Cheers.
The top plate has screw holes in it, I am just not sure if they are correctly spaced for the WiiM Sound
