Level slider control for PEQ.
uffe
Location
Sweden
Suggest a slider control for PEQ level. I'm thinking of something similar to Roon. I use it with headphone PEQ. Convenient to shift the entre curve up/down with a simple slider control.
Upvote 2
yep, been requested multiple times by multiple people for over 6 months, and it's quite a standard, important, and simple feature but has yet to be added, no clue why. u can upvote these:
Thread 'EQ Pre-Gain per Saved EQ'
https://forum.wiimhome.com/threads/eq-pre-gain-per-saved-eq.7800/
Thread 'Pre-gain per EQ profile'
https://forum.wiimhome.com/threads/pre-gain-per-eq-profile.3765/
Why a slider just for the level? Why not for frequency and Q?
Why a slider anyhow? As soon as you tab one of the filters you can actually drag the marked dot around in the graphical display, influencing the frequency, the level and the Q factor (edit: not the Q factor, of course), all at the same time. In which respect would a single slider be better than that?
Edit:
Ok, I didn't read this part ...
... shift the entre curve up/down ...
... sorry. Totally different thing.
Yes, why make it more complicated with a slider control. A numerical "attenuation/gain" input-box is maybe sufficient, and even a better solution.
