Hi everyone! I’m new to Wiim and new to the forum and wondered if anyone had any experience with this particular issue I’m having…
I bought the Wiim Pro Plus recently as a dedicated solution for expanding my turntable across my network. I went with Wiim based on the great reviews and the Pro Plus specifically because of the high-spec ADC.
I have a mid-high-end Roksan Attessa turntable with a built in phono pre-amp. I've tried a few different configurations, but the resulting sound quality when paired with the Wiimis unexpectedly poor. There is very little clarity, particularly in the mid and low frequencies, and there's an overbearing crackle/static that takes over when certain frequencies play, resulting in an unlistenable experience.
I’ve been in touch with Wiim about this and with nothing showing in the log, they suspected a faulty ADC (which I also suspected). However, the replacement unit is doing the exact same thing. Here‘a a few details for wider context:
Thanks I’m advance Wiim community
- The turntable works perfectly – when wired directly into my speakers, the sound quality is perfect, so there’s no obvious issue here.
- The cables are in good working order. I've tried 3 different line-in connects between the turntable and the Wiim – all brand new. The same cables work fine when I bi-pass the Wiim as well.
- I have a high-speed home network
- My networked/bluetooth speakers work perfectly, and also work perfectly with the Wiim when playing Spotify over Airplay or Bluetooth. The issue seems to occur when the source is line-in and the ADC comes into play.
- I experience the poor sound issue in multiple scenarios when using the Wiim and line-in is the source:
- When airplaying to high-quality Naim speakers
- When using my Naim speakers as Bluetooth receiver
- Even when hardwiring into my speakers via line-out on the Wiim
- These scenarios suggest that issue might lie with the signal processing
- In addition, I've tried adjusting the line-in sample rates from low to high, which didn't make a difference.
