audiophile_1298
- Sep 10, 2025
I have had the Wiim Pro for over a year now and have been using it as a streamer with a Cambridge Audio Dacmagic via optical out.
Had no issues when new but as of last 2 months (and most likely from last firmware update) i am facing an issue where when I turn on and try to play music via Tidal- I can see the sample rate of the file on the Dacmagic plus but can only hear a loud constant tone noise via the speakers.
I have to turn both the Wiim and DAC off and on multiple times before it just works as normal.
The DAC is definitely not an issue as I have plugged it into different sources and it works absolutely fine.
Been scratching my head with this and getting super frustrated as its a good 30 mins before I can sit back and listen to some music.
Anyone insight/advice would be much appreciated!
