Missing EQ/ room correction profiles after Firmware update
Redredbettyz
Welp, I keep up with the firmware updates pretty regularly. Upon my most recent update, my room correction profiles (all but 2-3) were all wiped out. I had a feeling that something like this would eventually happen, so lucky for me, I took screenshots of my favorite room correction settings and now have to take the time to punch them back in manually.
Just thought I would spread the word to find a way to document some of your favorite settings so you don't have to start from scratch in the event that this happens to you.
Also, is Roomfit just a rebrand of the Room correction with a few feature changes?
Are you sure the room correction profiles were wiped out or were they just moved to a new location in the app?
How many profiles did you have in total before the update?
6-7 profiles. There were three left after the FW update. I am not upset in my case, I just thought I might raise awareness in the event that someone put in a lot of time tweaking a profile and the potential to have it vanish.
You didn't sound too upset. :)
It might just be helpful to find out if a very large number of profiles might have triggered the problem, but six to seven is not that much. If I remember correctly, @slartibartfast had a similar number of profiles with his WiiM Amp.
Are you sure the missing profiles aren't hidden behind the "see all" button? I only see three but another six appear when I tap "see all"
