Rocky De Angelis
- Apr 15, 2026
More detailed group options:
Ability to create a persistent group with options for input, EQ, and balance and possibly more.
One use case- use a preset button on the remote that is designed to select a persistent group which pairs two Wiim devices for Dolby 5.1 while simultaneously changing the input to HDMI ARC. The preset number one could then be named “hone theatre”. You can have the EQ for the multiple devices saved for this specific use under groups. One button and you are set for home theater. I currently also use grouping to link two devices when listening to vinyl and manually adjust the EQ and which device handles left and right channel. One step preset configuration would be fantastic and allow for easier ecosystem integration and customization. Once set up, your personalized system becomes faster and more user friendly
Upvote
