The options available might depend on what you are playing / streaming, and how.To be more specific, item 2 (More button) is in a different location and has more options than mine. Mine is missing the first two options, "Add to favorites" and "Add to playlist". The rest are the same. I really would like to have the two missing options.
From the Amazon app, or the wiim app?I am streaming Amazon HD with 5G WiFi or a Lan cable. Anyone has these two options streaming Amazon HD?
I no longer have Amazon to try this myself. I'm sure others who do will jump in...I am streaming Amazon HD to my Wiim Pro using the Wiim Home App. While it is streaming, the "Now Playing" window is as shown in the second picture above. The "More" button is missing the two options I really like.
I think the "image 2" you posted is Deezer.I am streaming Amazon HD to my Wiim Pro using the Wiim Home App. While it is streaming, the "Now Playing" window is as shown in the second picture above. The "More" button is missing the two options I really like.
Have not done casting before. Will give it a try. Guess then I will have to switch back and forth between Amazon and Wiim Home to use the equalizer, etc.So maybe amazon don't provide a way to add to (Amazon) favourites / playlists when playing via a 3rd party app, such as the wiim app.
Or maybe wiim haven't implemented it?
Either way, why not use the amazon app and cast to the wiim from it instead of using the wiim app?
That way surely you could add to favourites etc., as it'd be the amazon app you'd be using.
Unless you're in Poland!![]()
Do I need additional hardware for AlexaCast? Will sound quality to be different? I am quite happy with the sound quality now using Wiim Home.Yes, we can't add songs to favorites or playlists in the WiiM app. I think this is due to a limitation of the Amazon API.
AlexaCast solves the problem.
No, no additional hardware is required. The sound quality is the same for both. Log in to Alexa with the WiiM app and you will be able to use casting in the Amazon music app.Do I need additional hardware for AlexaCast? Will sound quality to be different? I am quite happy with the sound quality now using Wiim Home.
As said above, it may not be within WiiM’s powers - it is more likely that the Amazon Music API restricts it. It’s probably a read only interface i.e. WiiM can play tracks etc sent from Amazon, but it can‘t update your amazon music account with properties like favourites or new playlists.Hopefully Wiim can update the app to allow adding to favorites and playlists.
