I want to setup a PC to output audio to the WIIM Amp. I have reviewed a lot of documentation regarding this. One solution is to connect the PC headphone jack to the WIIM line-in ports with a 3.5mm to RCA connector. Is this a reasonable solution with good quality sound?
Other solutions that utilize DLNA/music streaming apps seem to be overkill. I do not own that much music. The PC and the WIIM Amp are on the same network. If there is a network solution, that would be better than a direct connect to the WIIM, but I don't see one.
My music streaming service allows me to create playlists but the WIIM Amp does not recognize the playlists. So, the goal is to be able to play playlists through the streaming website to take advantage of the high-quality speakers attached to the WIIM.
