please help to organize and random use
servit00
Hi everyone. I'd like to play music in FLAC format from some folders on my smartphone. Even though I have custom folders, when I search for local files using the Wii Home app, I see hundreds of files without the divisions I'd made in my folders. Question 1) Is there a way to view them as I'd like and as I explained? 2) Is there a way to listen to them randomly, as I don't see this option? Thanks.
If you're on an Android phone, under My Music you should see a Local entry and the number of tracks it has found. Selecting that should take you to a page with headers for albums, album artists etc including a Folders view. Even if you haven't tagged your tracks, I'd guess the folders view should still show the folders on your device.
If you're on iOS, the files need to be seen by the Apple Music app first otherwise the WiiM app won't see them. Plus I don't think the Apple Music area has the concept of folders so that's why I assumed an android phone above..
Unfortunately the Apple Music ecosystem doesn't support FLAC to my knowledge (and a quick non AI search to confirm).
