ElectroChris
- Nov 8, 2023
Hi! I am from a different audio world (commercial) and seeking a solution. I need input audio here, and play it there. There is a standard TCP/IP network between them. Can I use one Wiim pro as an input, and another as an output? I would like this setup to be set and then forgotten - with no interaction with the devices to make them work. Dante is the pro version of this, but uses a different comm protocol and will not work over a network with a WIFI link.
What do you think? Or do you have another solution? Perfect world - would be a copper run. But it is 1000' outdoors between 3 buildings.
