Can I set one of my Presets to be a little lower volume? An open network stream station I listen to is about 5db louder than anything else. I want to lower it to be less of a jolt when I choose the preset.
Dude!
So, if you set a preset for the station, then go to settings/presets then tap the three dot menu beside the preset you have set, then just adjust the volume to suit.
Don't forget to hit save
