Presets custom volume
hgo58
Location
Copenhagen
Sometimes when I activate a Preset with custome volume set, the volume do not get modified. This especially happens when the WiiM is on standby when starting the Preset.
I have a Preset with custome volume set to 20%. I just pressed it in the WiiM Home App and the WiiM Ultra started to play at 80%. The last volume used before going into standby.
Have anyone noticed this behaviour? Or other Preset settings not applied?
As far as I have checked with Amp Ultra, it works fine. Have you already tried rebooting the device?
Yes. Many times. It's not a new issue.
It happens in average once a week, so not so easy to debug. Probably a timing error when going out of standby.
Just wanted to hear if others have experienced the same. Maybe you don't notice it because the volume is already close to the one set in the Preset?
Anyone would immediately notice a difference in volume of at least 5%. 🙂
When returning from standby, does the preset input switching happen at the same time?
I will test this carefully when I have more time.
Yes, the input is switching. Just not the costume volume.
It's hard to test, as it's not happening that often.
