Are there any physical differences between the Pro and the Pro Plus? All the pictures I've seen they look identical. Is the Plus labeled in some way?
Are there three Pro retail options now:
Pro
Pro with remote
Pro Plus with remote
I have one and am planning on getting more but will need a way to tell the Pro and Pro Plus apart because I move things around over time and will eventually forget which one is which - plus it seems that WiiM is planning on continuously improving their product so the later versions will likely be different.
By the way, how do you pronounce "WiiM" in English? Is it "weem" or "wee - emm" or "whym" or something else?
Pro
Pro with remote
