Problem with playlist adding
I can add qobuz playlists ro favorites. And delete too. It just doesn’t work. I press Add To Favorites and nothing happens.
I add it in native qobuz app and then I can see the added playlists in Wiim home app.
I tried to reinstall the wiim home app, relog in to qobuz account. Still can’t add. Albums add perfectly, but not playlists
I received my Wiim Amp Pro and attached my new speakers on Thursday, April 17, 2025. I chose Qobuz and loaded it into the Wiim Home app. I am experiencing the same problem but it doesn't stop there. Let's say I search and find Beethoven Sonatas and add to my Favorites and Playlist. When I choose to play the sonatas it plays a very short part of each sonata and then skips to the next one. I want to hear each sonata completely. I have tried everything I can find to fix this and I can't. I don't know if having a separate Qobuz app loaded outside of the Wiim Home app is possible or if it would fix it. This is not going to cut it for me. I can return the Wiim Amp Pro and install a different system. Don't particularly want to but the music is number one and brand loyalty is down the list.
Did you log into your active Qobuz account in the WiiM Amp Pro?
Thank you for the reply. I loaded the Qobuz directly within the Wiim Amp Pro. I read that Wiim has been working on CONNECT software that will work better than the current method. It appears to be missing some of the features/options that Qobuz offers those that operate directly with the Qobuz APP. I appreciate your help.
