I have a pro plus that i can use for room correction. Is it possible to save the resulting PEQ curve and then transfer it to my WiiM mini for use in the same room?
One caveat of using WiiM Pro Plus as room correction measurement is that line outputs are likely different between WiiM mini and WiiM Pro Plus. For example, they use different DAC's - that's an apparent difference but there may be more difference.
You know Steve, despite all these frequency response being flat and that’s just about on any modern device but why some dac sound thin while other produce full bodied. If you look at their response was ruler flat.
