Kampernaut
Active Member
- Aug 6, 2024
Forgive me if these seem like ignorant questions, but:
1. If I set the Audio Channel to Mono, what is being sent through the Aux Out port? L, R, or the sum of the two?
2. If I plug a mono 3.5mm plug into the WiiM Mini's Aux Out Port, will that mono audio go over it? I ask because the Aux Out is obviously designed to have stereo plugs inserted. I'm not sure how a mono plug works in a stereo socket?
3. Will the result be different to me playing the stereo into a passive Stereo to Mono converter box that does sum the audio?
I'm asking because I plan to use a WiiM Mini as a source for a multi-zone amplifier that only takes mono inputs.
Thanks in advance for your help.
