Selfactual
- May 15, 2025
I cannot seem to connect to both of my Vibelink Amps simultaneously via Bluetooth. It's only one or the other. Is there a workaround?
It's not Bluetooth audio in the case if the WiiM Vibelink Amp, the USB connection is for configuration purposes only.Connecting a mobile phone to two receiving devices via Bluetooth audio simultaneously is generally not supported
And I fully agree. We are used to see all WiiM devices, even those on other networks, and the Vibelink Amp should be no exception, even if the technology behind the connection is slightly different.... just to see both amps listed in the WiiM home app. I think that’s a valid request.
Bluetooth is a point-to-point protocol. So, this is expected behaviour. Bluetooth can also be a hub-and-spoke (multiple clients) but the communications are still one at a time.I cannot seem to connect to both of my Vibelink Amps simultaneously via Bluetooth. It's only one or the other. Is there a workaround?
Yeah, and that’s my interpretation of all that the OP wishes to do. The fact that they say they can connect to just one at a time suggests it means they can see one as connected in the app, not that they wish (or can) do anything more than you state.Am I missing something?
All you can do with the bluetooth connection with the vibelink amp is turn the amp on or off and update the firmware. That's it as far as I know.
That is correct. Only one amp at a time will display in the app. If I disconnect one, the other shows up.Do you mean only one shows in the app? I’d suggest raising a ticket to WiiM via the more/feedback section in the app and seek their advice/opinion
Hopefully WiiM will react to your ticket and enable the display of both in the appThat is correct. Only one amp at a time will display in the app. If I disconnect one, the other shows up.
If the vibelink is fully asleep (lights off) when the power to it goes off then it will still be asleep when the power comes back on.OK thanks @Burnside I think if a remote trigger is not available then a smartplug will do the same. I just tried removing the power from the ultra and vibelink, removed the trigger cable then switched the smartplug back on and both devices came back on. As far as updates, I think you could end the bluetooth connection for whichever is connected under the phones bt connections and go about updating the firmware for both amps.
