Sub out doesn’t work Wiim Amp
okallevik
My Argon Sub 8 is not playing. It worked for a short while, but now it doesn’t work at all. I have tried disconnecting all equipment, rebooting, and reinstalling, but it still doesn’t work. Does anyone have a solution for this?
Can you check to see if your sub has been switched off in the app. If not raise a ticket with wiim and they will have a look at your logs. Sometimes with the wiim, rebooting is not enough, you may find that it helps to remove the power lead for a while.
Edit:
I had skipped the final sentence in the above post by @Ronnie D. Sorry. The idea is good though, so I second it.
Also make sure to not just reboot but really disconnected all devices from the mains power. Sometimes this helps after a firmware update.
