Sub Out Not Working on Amp Pro
Jarmel
I received my WiiM Amp Pro a couple of days ago and after setting it up, noticed that the subwoofer was staying on when it shouldn't and then simply not working when I played music. I ran a number of tests to confirm that the subwoofer was working, like running a separate signal directly to the sub from my iPhone.
It seems that the subwoofer out port on my Amp Pro after a period of time (hours) just does not work and the only way to fix it is to unplug the entire Amp Pro and replug it back in.
Submit a ticket to WiiM when this happens so they can inspect your device log to see if your unit is defective or if you have uncovered a bug in the firmware.
