KrimsonAudio
Active Member
- Jun 18, 2025
I'm using the Sub Pro RCA wired and the WiiM Amp Ultra. I am trying to figure out how to optimally use Roomfit. I have the options to use the Sub Pro Roomfit and the overall Roomfit with the subwoofer option checked. How should I do this? I ask because you can enable both "versions" of Roomfit independently.
Secondly, I was under the impression that Roomfit would set the crossover automatically based on its measurements. Is that incorrect, because it seems to only be able to be changed manually?
