Sync "Preset contents" and "Recently played" across devices.
Wiimer
Community Curator
Location
Japan
Hi, @WiiM Support , @WiiM Team .
This is a WHA feature request.
1, Sync "Preset contents" and "Recently played" across devices.
2, Backup & recover "Preset contents" and "Recently played" to phone.
Can these features be added?
Thank you for your consideration.
* Please refer to the image for 1.
Sync two pieces of data on multiple devices with the sync switch on. If it is off, it will not sync. This feature improves convenience when one person uses multiple devices together.
Upvote 6
and more modestly
Being able to sync the 'Open Network Stream' and 'vTuner' radio selections would be nice, too. I added a bunch radio streams and discovered, I would need to re-enter them in the tablet. Well, not the vTuner saves, if the station is being played, then you can just ❤️ it on that controller and it is saved there also. But I think a sync function would be great for a lot of areas, that I seem to keep finding :unsure: . Thank you.
