The dry/wet control after RoomFit calibration. (Similar to Sonarwoks).
Jay123
Hi, I thought it would be a good addition to WiiM. Then you would be able to hear better by ear what kind of filters RoomFit adds, and you could reduce the RF a little to get a slightly livelier sound and vice versa.
Many people are probably waiting for BassFit, so am I. It will really come in handy, because if you own at least an SVS (no pro version) subwoofer, whose own DSP adds about 5.5ms of delay, then the BASSFit feature is almost mandatory to get all speakers playing at the same time in sync.
AI is, by the way, pretty good at advising on PEQ filters if you give it a picture where the AI sees it when you play Pink Noise in RTA or FFT in real time. (Picture 1&2 'I'm playing hi-def Pink Noise').
After that, you just ask IA for a list where it will advise you to set PEQ filters to get an even more accurate frequency response. Or you can ask IA to make a correction if there is too much Hi-Hat, or you want more vocal sound, etc.
The next project would be when the BassFit arrives, as I have 2 subwoofers, to make them sound so that the second subwoofer cancels the room mode echoes around 50hz. (Picture).
So, the WiiM Pro PEQ filters are already set on top of the RoomFit correction, which IA suggests using to get an even smoother frequency response. Believe it or not, but to my ears, that IA trick works pretty well.
Or you can ask IA for the PEQ filter settings already in that RoomFit image, and it will suggest them, however you want. 🤗
Upvote 0
