Transient Rattle in Left Channel
Newzpix
Usually with a female vocal or instrument at a narrow and specific frequency, I hear what sounds like a the snare from a drum / metal fast rattle. I also hear it when doing a RoomFit. Does not occur when using CD transport or turntable, just the ProPlus
Can be (digital) clipping but unable to say without more info or an example. What do you mean "when doing a RoomFit". Roomfit plays a sweep..
First, I would listen to the source file again through headphones and check whether this noise is also audible. Alternatively, I would view the source file on a PC using an audio editor. If it is a poor RIP, this should be visible/audible.
This is to rule out hardware errors and errors in the audio chain.
