Hi to all
I would like to use a Trigger cable between the Ultra and my Topping D50 Pro Sabre. However, I am completely incompetent in this regard.
I need help. On Amazon I found this:
Would this be okay for the purpose? If not, can you suggest a short cable I could use? Possibly on Amazon.
I tried to do a search, but I don't know what kind of cable to choose.
Thanks for the help.
I have to use the cable because the Topping has an on/off if it doesn't receive a signal for a minute. It worked perfectly with the Mini connected to the Topping via SPDIF. Now, with the Ultra connected to the Topping via USB the On/Off via the signal no longer works.
