Try to reboot or factory reset if all things fail send message via wiim app.Hi,
I just had the v5.0.606744 firmware.
I just can't use Spotify now (connection is super long and does not work)/
Sub out seems out as well.
Everything was working fine before the update.
I've done a factory reset but the problem remainTry to reboot or factory reset if all things fail send message via wiim app.
Exactly.By cycling the power unit you mean unplug the power cable for a few minutes ?
I did that and it seems it helped on the sub out trouble.
Reboot and reset did not help on the Spotify thing
Power cycle = switch off and on again.Everything back to normal it seems
Thanks !
Just so I understand whats is this "power cycle" ?
Yes thanks ! Everything was back to normal the same day a few hours later fir spotify@bnino Just to confirm you're not longer experiencing any issues? What firmware do you have?
