ExactlyIt's the same for me each time. No bluetooth. I restarted my tablet : no result
maybe since the last firmware 4.8.524431 ...Exactly
Yes, this is visible max 1,5 sek. I managed to take a screenshot on the tenth attempt.I just launched WHA again.
Because I was looking for it I was able to see it; visible for less than 0.5 secs I reckon.
I'd have to be super quick to get a screenshot!
Android tablet, bluetooth not active.
This is working!!! ThanksI found an interim solution.
In the WiiM app permission settings, turn off "Nearby Devices". In this state, the dialog does not appear even if Bluetooth is turned o
It is not a WHA configuration. Common Android app settings.Sort for asking but where are the Permissions in the WiiM app please?
Have you tried the latest version of the WHA app?Thanks. Doesn’t work on my Huawei P30 Pro. Only option that shows this way is Uninstall. Accessed permissions via General Settings>Apps>Wiim Home>Permissions. But no option to close nearby devices. I don’t leave Bluetooth on for battery reasons, so I’ll just put up with the Unable to scan message as it’s literally only there a split second.
Thanks for the help
