Juliemeikle
- May 8, 2025
Can I plug the power cable directly in to a usb socket on a mains socket? Just had house rewired with 3 pin (in UK) sockets with usb -an and usb- c sockets. Also can I use another cable if I want to move it around and use the cables already in place? USB a only or is it ok to use a usb c to usb c lead?
Also would it work via a 12v system in a motorhome? Quite fancy replacing the Echo Dot in the camper with a Wiim mini
Thanks
Thanks
