F1 Fan
Senior Member
Hi all,
As per the subject line, any idea why?
HDMI in works nicely but not Optical in ..
Is auto sensing of optical input turned on?Hi all,
Yes ..There are no configuration options here.
Which device are you trying to trigger with the cable? Your DAC?
Is the Ultra turn on by Optical auto sensing?Yes ..
HDMI > Ultra > trigger > Dac - no issues
Optical > Ultra > trigger > Dac - does not work
Note that if you turned off Ultra using the remote's power button, Optical auto sensing may not work properly. Always turned off Ultra via auto-standby.Yes, the ultra is turning on .. I’ll try again tonight and report back
I have the same behavior with the optical input NOT sensed, but the HDMI Arc IS always sensed ... I wil try the suggestion to auto-standby the optical ... because with the HDMI ARC is auto-standby when TV is switched off ...Yes ..
That's good.Got it sorted .. thanks all
