Vibelink Smart Plug & Remote 3
Wiimer
Community Curator
Location
Japan
❤️It's a fictional product. You can't buy❤️
The new Vibelink device is finally complete 😂
This time, it is a power strip equipped with a smart remote function.
💛 Vibelink Smart Plug 💛
<Main Features>
  1. Equipped with 4 power plugs and 2 USB power ports.
  2. Wi-Fi and Bluetooth connectivity.
  3. Automatic on/off for each power source (with scheduling function).
  4. Manage power consumption and device status.
  5. Supports automatic FW updates for linked devices.
  6. Work with Alexa / Google Assistant.
  7. Matter support.
  8. IR/RF Smart control.
  9. Various device protection features such as surge protector.
  10. Stackable with WiiM Ultra series.
  11. Also support to enthusiastic Audiophiles.
Vibelink Smart Plug automatically manages the power supply of audio devices via a network connection. You can also turn the power on / off manually from the main panel or WiiM app.
Manage the power consumption of all devices connected to Vibelink Smart Plug. And display the status of WiiM devices linked to the app.
Vibelink Smart Plug is receive WiiM device update notifications via the auto-update feature. When the Vibelink Smart Plug receives a notification, it turns on the device's power, performs the firmware update, and then turns the power off again. This feature prevents temporary issues after the update.
Work with Alexa / Google voice control and routines. The Vibelink Smart Plug functions as a WiiM remote via Bluetooth. And Matter compatibility allows control from other smart home devices.
Vibelink Smart Plug has a built-in infrared remote control, enabling control of any home appliance.
Pull out the stand on the back panel and place the included top aluminium plate on it. It becomes the same size as the Vibelink Amp, and can be stacked with the WiiM Ultra or WiiM Amp Ultra.
Equipped with standard protective features. Additionally, it uses high-quality components that audiophiles will appreciate 🤗
We also offer the Vibelink Smart Plug Pro, which is equipped with 32 customisable preset buttons and a display screen.
<Suggested price>
Vibelink Smart Plug : ~70 USD
Vibelink Smart Plug Pro : ~100 USD
If you want one, please reserve (vote) now 😂
Does the Vibelink Smart Plug Pro come with a full function remote control in order to access all of the additional functions, such as the presets, etc. :unsure: :)
A remote is not included, but a Bluetooth remote is built into the Vibelink Smart Plug itself, allowing you to control presets on the WiiM device using Alexa voice control and routines 😄
(Maybe 'Matter' support would make this possible.)
I don't use any kind of Voice Control, so possibly there should be an optional accessory of a physical remote control. :unsure:
The thread title mentions the Remote 3, what does this look like? :unsure:
Vibelink Smart Plug built-in remote that controls a WiiM device linked via Bluetooth. It's like a Smart Hub, not a manually operated remote 🙂
TAKE MY MONEY!!💰
So what is the idle power draw of these devices when all ports are off? Do I need to put a smart plug ahead of this smart plug? :LOL:
Y’all had me right up until you got to describing the Pro version. I was about to throw down money today because it would have solved an issue of having an untriggerable amp I want to use without physically going to the amp to turn it on each time I want to use it.
Untriggerable amps that automatically return to full power-on status when power is restored can easily be resolved with a Panamax M8 AV Pro power strip with 4 high-current 12V-trigger-activated sockets.
-Ed
TAKE MY MONEY!!💰
Most smart plugs and smart hubs will work at around 1~2 W 😄
Sorry, I added a note of caution 🙂
